Unable to access router via HTTPS 8443 on 380.63_2
amplatfus
I just activated HTTPS on 8443 port and I cannot use it. Router page is loading very slow in Chrome (tested from phone also, from intranet and from internet).
The page in slowly loading with message: establishing secure connection. In the end the page is loading, but after few minutes.
Please, do you encounter this situation? I am on 380.63_2.
Thank you.
I would not enable access to your routers WebUI from WAN. Use a VPN to log in from LAN only. This is much safer.
And if you trust your LAN, you can then disable https, as slow page loading is the undesired trade-off when using a secure connection.
Search this forum, there are several threads discussing this.
