spdMerlin Unable to perform speedtest
marko
When i try to run speedtest via spdmerlin addon nothing happens. Screen is blank after i click on the run test button.
Also, I am unable to disable automatic speedtests as well as to store data on USB instead of JFFS. I go and click desired radio button, then i go to Save, and sfter save everything returns back to default settings.
Any suggestions?
Any suggestions?
Looks like some page resources haven't loaded, please can you check for errors in your browser's console?
Just fixed the issue. I did everything I wanted through GUI, just through amtm. I was able to run speedtest via amtm, then I got back to the GUI and everything works now.
@Jack you can explain if you know :)
When you first installed did you let the speedtest complete?
It's Merlin, It's Magic. Routers are so smart now they fix themselves.
Here it how it looks like after incomplete speedtest. before I had one interface row, and after i get second row.
syslog
