Solved Unbound stats went a little crazy after update.
Juched
I have an update . My cron jobs for Conmon,Spdmerlin,NTP merlin and UIDivstats were missing. So I force installed those scripts. Having done so I am now missing the Unbound Tab with exactly the same behaviour as previously. seems to habe been deleted by forceinstalling the other scripts. When I try and install the GUI tab from amtm it goes through install process but does not install the tab with colour remaining green after install and still showing up as not installed.
After rebooting all tabs back again !!
my the same problem
Hmmm some how the unbound stats call found it’s way into post_mount twice. Something tells me this is probably the culprit.
for me is work now, tanx!
v1.4.1 should correct this if there is a duplicate.
awesome! Reboot this morning with no problems. My removal of the extra call did persist through reboot and the stats page loaded up just fine.
I currently have it running in the background of post_mount w/ the ampersand at the end. Would you recommend keeping it that way? I want to say I added that manually but I can’t remember.
The new install (or upgrade) does that & automatically now. It also ensures it only runs once when the entware partition is loaded.
