Updating dnsmasq.conf.add does nothing
PickleTickle
All I want is to be able to redirect certain URLs on all devices connected to my router to a local ip address (e.g. router.local in the browser should send me to 192.168.0.1)
I have updated the to contain a single line
> cat /jffs/configs/dnsmasq.conf.add address=/test.com/192.168.0.80 > service restart_dnsmasq Done. > cat /etc/dnsmasq.conf ... address=/test.com/192.168.0.80 >dnsmasq -q >dnsmasq --test dnsmasq: syntax check OK.
but when I go to test.com on any device connected to the router, it just times out. Going to 192.168.0.80 navigates to my unraid server as expected.
I followed this multiple times to make sure it was correct (after resetting all changes on the router) https://github.com/RMerl/asuswrt-merlin.ng/wiki/Custom-domains-with-dnsmasq
Firmware:3004.388.4_0-gnuton1
Router: RT-AX82U
Any ideas?
Router: RT-AX82U
Any ideas?
Have you followed sections 2) «Adjust router configuration» and 3) «Adjust DHCP Server Options» of Merlin's instructions?
I've not played around with dnsmasq but did "cat /etc/dnsmasq.conf" on my router and it appears "," is the delimiter. The only places I saw (right off) "/" was to locations within the router's filesystem. Though the syntax check passes for you I have to ask whether you're setting that value correctly.
Another question that comes to mind is, instead of "translating", why not just use the /actual/ location in your requests, instead?
figured it out - pihole revived itself and was acting as the dhcp server instead of the router.
Unplugged it and ipconfig /renew seems to have solved it
guys anyone have a copy of dnsmasq.conf with BBC Player ITV Hub, Channel5 and channel4 domains to whitelist? channel 5 and channel 4 seem to stay blocked then i use them
