Using a script to populate an ipset set with DHCP addresses
Denna
I'm trying to create a script that adds DHCP addresses to an IP set.
1) Determine the DHCP address range with the following values.
nvram get dhcp_start = 192.168.1.2
nvram get dhcp_end = 192.168.1.4
2) Create a DHCP IP set called DHCP_CLI.
ipset create DHCP_CLI bitmap:ip range 192.168.1.0/24
3) Add all IP addresses with the range of dhcp_start and dhcp_end to the DHCP_CLI IP set.
ipset add DHCP_CLI <dhcp_start value>
ipset add DHCP_CLI <dhcp_end value>
In step 3, how would you iterate through the dhcp_start and dhcp_end values to add the following to the DHCP_CLI set ?
192.168.1.2
192.168.1.3
192.168.1.4​
Step 3:
#!/bin/sh
startIP=$(nvram get dhcp_start)
endIP=$(nvram get dhcp_end)
loopIndex=${startIP##*.}
while [ $loopIndex -le ${endIP##*.} ]; do
  echo ${startIP%.*}.$loopIndex
  loopIndex=$((loopIndex+1))
done
@redhat27,
That's amazing !
The DHCP range would probably be less than 10.
To add each IP address to an IP set, would you replace the echo line with ...
ipset add DHCP_CLI ${startIP%.*}.$loopIndex
