alfa147x
Trying to clean some wires up and I'm looking for for a panel mount connector. It looks like most wifi devices use RP-SMA adapters. I was wondering could I just use a panal mount for regular SMA / TNC in between? Any disadvantage?
or
How does soldering work with these types of cables? I've soldered plenty of audio cables (including finicky 3.5m cables) but never any RF cables. Is it not worth the hassle?
Also I'm thinking about moving to TNC connectors because they're easier to connect / disconnect. Is that a bad idea?
The goal is to protect an AP that a friend uses during football games. Some how these devices get trucked during transportion / during the game. They've gone through 4 this season. I'm thinking of putting the AP in a pelican case and using panel mount connectors for quick connect / disconnect.
Thanks,
Alfa
Thanks,
Alfa
