Yes you can. Just remember that you've done this because if you ever do a factory reset on the router then WAN port will revert to being the normal 1GbE port.what i want to know is the other 1gig wan port that im not now using cause i using the 2.5,can i use it as a extra lan port
We use essential cookies to make this site work, and optional cookies to enhance your experience.
