VLAN DAS share issue on 88U Pro
shanetrain
Hoping I can get some help.
Runnimg a VLAN with 1 device on it with a DAS attached.
I cannot for the life of me access the DAS share from my LAN.
I am able to RDP locally into the machine on the VLAN, but cannot get the share to show up.
I have pulled countless scripts from Google for a firewall rule to allow the share to show up, but I am at a point that I am stuck.
My understanding is that I should be able to create a script that will allow LAN clients to access the VLAN DAS, which is attached to a Windows 11 machine.
Any ideas?
TIA!
rough guess - permissions issue, file sharing issue on the WIN 11 machine hosting the DAS and Share if you can ping the WIN 11 machine from the client devices.
Yes, I can ping the machine from the LAN, I just can't get the network share to show up the LAN.
Paste your firewall rule in here so we can have a look if you want a double-check, but as @degrub suggested if you can talk to the machine on the VLAN from the regular LAN it's likely not related to the firewall.
