I have read that for OpenReach FTTP the VLAN isn't needed. I'm hoping this is the case.
I am using an RT-AX58U router and the WAN port is on eth4
However, in case it isn't I was looking at scripting a /jffs/script/services-start to set up the VLANs based on the need for 101 for OpenReach and 911 for city fibre.
Example:
However the output of
currently doesn't include eth4 in the bridge:
If I did need to set up a VLAN, would the above script (with the correct lines uncommented) work or should I be doing something different?
Thanks in advance
Example:
#VLAN Settings for Vodafone - Uncomment relevant lines below if needed.
#Create the VLAN interface on the WAN port (e.g., eth0, check your router's specific interface)
#ip link add link eth4 name eth4.101 type vlan id 101
#ip link add link eth4 name eth4.911 type vlan id 911
# Bring the VLAN interface up
#ip link set eth4.101 up
#ip link set eth4.911 up
# Assign the VLAN to your desired network bridge (e.g., br0 for WAN)
#brctl addif br0 eth4.101
#brctl addif br0 eth4.911
brctl show
eth0
eth1
eth2
eth3
eth5
eth6
wl0.1
Thanks in advance
