voip server gets "kernel: [BLOCKED - INVALID]" message
Bruce Campbell
My SPA2102 appears to be working fine with with voip.ms. The SPA2102 is behind an ASUS RT-AC68U running Asuswrt merlin 384.8_2.
The calls are clear, but I am simply curious why I see the message "kernel: [BLOCKED - INVALID] ..." exactly 5 seconds after the call starts and exactly every 5 seconds thereafter in the system log until the call ends. The voip server is indicated as the src ip in the message, as shown below:
Jan 31 13:04:34 kernel: [BLOCKED - INVALID] IN=ppp0 OUT= MAC= SRC=<voip.ms server ip> DST=<my ip> LEN=92 TOS=0x00 PREC=0x00 TTL=61 ID=0 DF PROTO=UDP SPT=10433 DPT=16714 LEN=72
... <5 seconds later> ...
Jan 31 13:04:39 kernel: [BLOCKED - INVALID] IN=ppp0 OUT= MAC= SRC=<voip.ms server ip> DST=<my ip> LEN=92 TOS=0x00 PREC=0x00 TTL=61 ID=0 DF PROTO=UDP SPT=10433 DPT=16714 LEN=72 MARK=0x80800000 <a variety of different MARK values are often shown here>
When I call from my smartphone using the Groundwire app through wifi I don't see the same message, so I assume it is something specific to the SPA2102. So, since it had been years since I adjusted the settings, I factory reset the SPA2102 and adjusted the settings according to the voip.ms wiki again. Still have the messages.
I am just curious whether anyone has seen this before and knows what is causing it ...
You are probably logging invalid packets in Skynet.
I thought the same thing. So the first thing I did was whitelist the ip in skynet -- but no change. I then deactivated skynet completely -- no change. In addition, it occurred to me later that my smartphone connecting to voip.ms through wifi should also generate these messages, but it doesn't.
I have my suspicions that it is Trend Micro's AiProtection, but I checked the Trend Micro database to see whether the ip for the voip.ms server was there -- and it wasn't.
So ... I should probably just ignore it, since this is all so cryptic I probably won't learn much from the answer anyway :-)
