Voxel Voxel Firmware on LBR20 - Preshared Key on WG client
UndyingShadow
I'm using the latest Voxel Firmware on an LBR20 with the Wireguard client. The Quickstart.txt indicates to use the following template for the wireguard.conf file:
------------------------- cut here ---------------------------------------
EndPoint="wireguard.5july.net"
LocalIP="10.0.xxx.xxx/24"
PrivateKey="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX="
PublicKey="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX="
Port="48574"
Problem is that I'm trying to connect to a VPN provider that provides a Preshared Key.
The WG VPN client doesn't seem to work without it.
Trying a different provider without a PSK does work. Is there a way to specify this?
I tried PresharedKey="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX="
/etc/init.d/wg-client appears to be responsible for creating /tmp/wg0.conf
It doesn't have anything for parsing PSK out of the wireguard.conf file.
# WireGuard: create wg0 config (wg0.conf)
echo "[Interface]" > $WGConfig
echo "PrivateKey = $PrivateKey" >> $WGConfig
echo "[Peer]" >> $WGConfig
echo "PublicKey = $PublicKey" >> $WGConfig
echo "Endpoint = $IP:$Port" >> $WGConfig
echo "AllowedIPs = 0.0.0.0/0" >> $WGConfig
I tried to modify the script but my changes do not persist.
The use of PresharedKey is optional and VPN provider (I could use for testing) does not support it.
OK, I'll add this optional PresharedKey support to wg-client, but I cannot test it.
Check my QuickStart.txt re: how to keep your changes.
2. Overlay partition on Circle partition.
You should save your changed script as
/mnt/circle/overlay/etc/init.d/wg-client
Change it to:
if [ ! -z "$PresharedKey" ]; then
echo "PresharedKey = $PresharedKey" >> $WGConfig
fi
It is what I'll change.
Voxel.
Okay, cool, I didn't know if the overlay would allow to overwrite existing files.
Thanks for the info and for the fix. And thanks for the firmware, it is very much appreciated.
I can confirm this script edit works, both with and without PresharedKey in wireguard.conf file. Both types connected and completed speedtest through VPN
