thegios
Hi, I have two XT8 nodes in a mesh config, node 1 is connected by cable to the operator's modem/router which is used just as a modem (all rest is disabled), node 2 is connected by wireless backbone to node 2. All cabled devices are connected to node 1 or node 2, including the Android TV box used for streaming.
I would like to setup a VPN to be turned on at need for being able to access USA catalog on Disney+ , Netflix etc.
I know I could install a VPN on smartphone, on PC and on TV box, but I guess setting up a VPN directly on the XT8 is easier?
Thx
Thx
