I have a dedicated IP with NordVPN and I have an .ovpn config on my RT-AX86U (running Merlin) to put all of my traffic over that VPN. Everything has been going great. However, just recently, I can no longer log into Disney+ on my network! I try to hit the login page, and it says Disney+ has encountered an issue!
I've done my best to troubleshoot, but I'm at my wit's end. Here was my troubleshooting so far:
Q: Disney+ could be down?
A: Negative
Q: Maybe my Dedicated IP has been blacklisted!
A: I can VPN to my Dedicated IP via client software on my Android phone and Linux laptop via the same technology/protocol as my router's connection (OpenVPN/UDP), and it works when I VPN on the client device!
Q: Maybe there is a DNS leak? Maybe some general DNS funkiness? I do run a PiHole as the DNS on my network.
A: On the client devices, I can put in public DNS servers (Cloudflare, NordVPN's DNS servers, etc.) and I still have the same issue. On my linux machine, I changed `/etc/resolv.conf` to exactly match what it gets set to when I connect to my VPN with the nord client software (`nameserver 103.86.96.100` and `nameserver 103.86.99.100`). No luck
Q: Browser caches? App caches?
A: Yeah... that's why this has taken so long! I have been clearing those. However, I don't think I need to, because when I switch the client nordvpn software on/off, I see imediate results in my browser by just refreshing the login page (it works with the client software on, and doesn't with the client software off).
So that's about as far as I got. I'm wondering if it could be a DoT or DoH thing? But I'm not really sure how to flip that switch on/off or how to tell if that switch is getting flipped on/off when I turn on/off the nordvpn client software. I really doubt it since I would think that's something my browser is in control of? Or maybe not? I think I've tried every combination of `Enable DNS Rebind protection`, `Enable DNSSEC support`, and `Prevent client auto DoH` (I've landed on "No" for all of those which I think is where I started").
Does anyone have any tips to help me run this down?
A: Negative
