VPN tap tunnel: client side only on a specific ethernet port
ronzino
Hi
I have a Asus RT-AC68U with asus merlin firmware.
I would like to know how to set up a vpn tunnel as follows:
My asus shall act as a VPN TAP client, BUT only a specific lan port must be assigned to use the VPN tunnel (lets say port3).
Doing so whatever devices are connect to this port3 (using a second switch) are managed by remote DHCP server (VPN server segment).
Sp my question is....how can I tell to asus merlin "this VPN Tap tunnel must be binded to lan port 3, all the others ports (1-2-4) have not to be tunneled " ?
many thanks
nobody know?
I wonder if something like this would be possible..... create a vlanA for Port 3 and a vlanB for all the other port.
then assign a tap vpn to vlanA
but I am not skilled in e tables and rules to create in order to do this.
Assign a TAP VLAN to vlanA
Do you actually need to use a TAP VPN Client?
If you can use a TUN VPN Client, then you could use something like:
e.g. Map switch Port 3 to VPN Client 1 VLAN10
./WiFiVPN wl0.1 1 autodnsmasq
./VLANSwitch.sh 10 3 vpn1 notag autodnsmasq
I need tap as I have to move the whole frames dhcp arp vol packets etc etc....basically all services that do not live at layer 3
