Wan connection DHCP 802.1q ?
Yes it is via CLI, not sure about priority part.
If you could share more details about particular desired config, including vlan id`s, then I may able to provide you an needed commands to set it up or maybe even an script, which does it automagically.
hi,
Provider ORANGE fiber 1Gbs
Wan DHCP (option 90 ) Vlan 832 priority 6 (ICMPv6, ARP, DHCP, DHCPv6)
Traffic priority 0
Orange change PPPoE to DHCP (ipv4 - ipv6)
excuse me for my bad english , i'm french
Sure it requires vlan tagging on WAN?
It`s a bit uncommon to have a single vlan and 802.1q enabled simultaneosly. :rolleyes:
It is PPPoE so it should be doable in GUI, no special config needed.
You should be able to tag WAN vlan form commandline with:
robocfg switch enable port 0 state enabled stp none tag 832 jumbo off vlan 832 ports "0t 8t"
Or even better, use GUI as that commandline is not persistent, unless you script it.
LAN -> IPTV and set Internet vlan to 832
it's possible to make this :
interface "vlan832" {
send dhcp-class-identifier "sagem";
send user-class "+FSVDSL_livebox.Internet.softathome.Livebox3";
send option-90 00:00:00:00:00:00:00:00:00:00:00:66:74:69:XX:XX:XX:XX:XX:XX:XX:XX;
XX = my login HEX
on RT-AC68U with merlin firmware ?
Because my provider Orange FTTH change PPPoe (vlan 835 Prio 0) connection to DHCP (vlan 832 Prio 6 for packets ICMPv6, ARP, DHCP, DHCPv6-pd )
Thx
Anyone can help me ?
DATA : data now coming in vlan 832. The frames encapsulate packets ARP, DHCP, ICMP are tagged with a Class of Service (CoS) 6 and "normal" packets to 0
VoIP: the voip happens in the VLAN 832 also. The frames encapsulating SIP and RTP arrive with CoS 5.
TV : tv is on vlan 840. Prio CoS 0
