SashaSolitaire
I have purchased the ASUS router above and am facing consistent issues with it. Help appreciated.
Setup:
ISP - Verizon FIOS (MI-424 router)
Router - ASUS RT-AC88U
Firmware: 3.0.0.4.380_7743-g2cf84e9
Signature: 1.170 Updated : 2017/06/27 14:15
Connections:
FIOS ONT -> Coax ->MI-424 (set up in Bridge mode) -> LAN Port 1 of MI-424 -> WAN port of ASUS router
Also hooked up to the ASUS Router
1) Netgear ReadyNas 212 to ASUS LAN ports 1 and 2 (with link aggregation). The NetGear also runs my Plex server
2) CAT 5 to living room from ASUS LAN port 3 which is connected to the XBOX
3) CAT 5 to office from ASUS LAN port 4 which is connected to a TP-LINK SG105E (serves two Windows desktops)
Both 2.4GHz and 5GHz bands are active on the ASUS. Multiple wireless devices (AV receiver, iPads, tablets, phones etc.,) are connected to different bands.
Issue: The router works fine, but then randomly, sometimes within an hour, or sometimes over 6- 8 hours, does not let any device connect to the internet. To be clear, all the devices are either on the wired or wireless connections, but cannot connect to the internet. If I had a page open on my browser where I had logged into the router, I would be logged out when this happens. Once I enter the credentials, I can log back in, but still cannot connect to the internet. There is a valid WAN IP, but still cannot connect to the internet. A reboot at this point of the ASUS router invariably restores the internet connection.
A section of the system log between the reboots is provided below
Jun 29 09:43:00 rc_service: ntp 883:notify_rc restart_upnp
Jun 29 09:43:00 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Thu, 29 Jun 2017 13:42:58 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Jun 29 09:43:00 ddns update: retval= 0, ddns_return_code (,200)
Jun 29 09:43:00 ddns update: asusddns_update: 0
Jun 29 09:43:01 rc_service: ntp 883:notify_rc restart_diskmon
Jun 29 09:43:01 disk_monitor: Finish
Jun 29 09:43:01 ddns: ddns update ok
Jun 29 09:43:02 disk monitor: be idle
Jun 29 09:43:03 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Jun 29 09:43:04 kernel: sizeof forward param = 160
Jun 29 09:43:06 rc_service: udhcpc 609:notify_rc start_firewall
Jun 29 09:43:06 dhcp client: bound 96.232.XXX.XXX via 96.232.XXX.XXX during 7200 seconds.
Jun 29 09:43:07 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jun 29 09:43:22 dnsmasq-dhcp[533]: Ignoring domain <<WIFE's OFFICE DOMAIN>>for DHCP host name WPMUTHU-SURF
Jun 29 09:43:30 crond[542]: time disparity of 1005943 minutes detected
Jun 29 09:44:48 hour monitor: ntp sync fail, will retry after 120 sec
Jun 29 10:00:02 disk_monitor: Got SIGALRM...
Jun 29 10:32:53 dnsmasq-dhcp[533]: Ignoring domain<<WIFE's OFFICE DOMAIN>>for DHCP host name WPMUTHU-SURF
Jun 29 10:33:35 dnsmasq-dhcp[533]: Ignoring domain <<WIFE's OFFICE DOMAIN>>for DHCP host name WPMUTHU-SURF
Based on research to mitigate this, the changes I made to the router are:
Change 2.4 GHz to 20Hz
Change 5.0 GHz to 20Hz
RTS Threshold to 2307
Beacon Interval to 50
Disabled uPNP
Changed DHCP Query Frequency to "Normal Mode"
Appreciate it if anyone can shed some light on what could be wrong. Let me know if you need more information
TIA
Sasha
Setup:
Connections:
Disabled uPNP
TIA
Sasha
