Want to change my Sky Q router
Martina37
Hi everyone I am new here and to upgrading routers. Please be gentle.
I want to upgrade my Sky Q router for something better.
My 15 year old son is a gamer both Xbox X and PC.
My eldest son uses Steam a lot and his computer.
We have a Sky Q main tv box and 3 multi room boxes
I want something that is future proof and will support the above and we have Alexa devices and mobile phones.
I would really love advice on what models of routers are best for us and they need to support I believe DHCP 60-61 MER. Will I need to load that firmware on to the new router a how do I go about doing that please.
Everything is on WiFi apart from the sky tv box. Not sure about hard wiring or to use some Devolo Magic 2 adapters as I haven’t a clue how I would feed cables from upstairs to downstairs to enable me to do this.
Sorry for the long post.
Many thanks
Martina37
Welcome to the forums.
With Sky I believe you need the third party router to support DHCP 60/61. Which would include most if not all of the newer ASUS routers that have DSL, AS LONG AS Merlin Firmware is Installed. I don't think ASUS routers support DHCP 60/61 without Merlin Firmware. ASUS would be my choice and installing Merlin firmware is not difficult with guidance on these forums.
Another option is TP Link Routers as I think most of the newer ones support DHCP 60/61 the VR2800 is a good choice.
As for Netgear these models are supported https://kb.netgear.com/000062426/Which-NETGEAR-routers-support-DHCP-option-60-and-61
Also you need to state your budget and what you are trying to cover, size of property, do you need AX or is AC ok etc ? (AX is the latest version of wifi, but overkill for most people right now)
I cannot make a solid recomendation of which ASUS router as I don't use DSL, however I am sure there are many using sky broadband on here that could help you further.
H
Hi
Thanks for taking the time to reply. My sons are saying the ASUS Routers too. Up to £300 is the budget, it’s to cover a 3 bed semi detached property.
I just need to know which models of ASUS would be best and then how to get this merlin firmware on it and where do I get the download from.
Would the WiFi be able to reach out in the back garden in case I decided to put a garden room out there ?
Not sure what you meant by AX or AC sorry
many thanks
It's available in stock Asuswrt, but I would approach carefully ISP boxes providing more than just Internet. I don't know what Sky Q hub does and if settings are open for modifications. Someone from UK may provide more details if Sky device can be replaced. Don't rush with router and firmware recommendations. @Martina37 may need better Wi-Fi only, not a new router.
H
Hi
many thanks
Would it work to the garden - depends on the positioning of the router, if its at the front of the house then possibly not, or weak at best.
AX vs AC https://www.minim.com/blog/wifi-6-vs-wifi-5-speed
I cannot recommend a router tho, because I dont know enough about DSL connections.
A review of Sky Q Hub says:
"The Sky Q Hub isn’t just a regular router though, instead it’s an integral part of the Sky Q system. That means the other components, your Sky Q set-top box and any Sky Q Mini boxes act as wireless repeaters, expanding the range of your Wi-Fi network."
From @Martina37 description:
"We have a Sky Q main tv box and 3 multi room boxes".
Sounds like some sort of home "mesh" Wi-Fi system. Eventual replacing of the main router means replacing of everything. Sky Community support forums perhaps have the right answers - https://helpforum.sky.com/
