Shonk
Has anyone ran into this before when i got up today
i noticed some of my devices wernt connected to the 2.4ghz on my RT-AC88U ap
after looking into it
Odyssey (which runs on channel 1 + 5 WPA2 AES)
Briefly shows up as Odyssey Open
then Odywsey channel 5 + 9 WPA2 AES (Note the w)
thinking it was maybe a config problem
rebooted to the mini cfe webserver
clearled nvram and flashed a fresh stock firmware
Its doing exactly the same thing on a totally fresh firmware with nothing changed
ASUS_70_2G then ASUW_70_2G alternating every few seconds
im unable to connect to either ap's i presume as they are switching back and forth constantly
i have factory reset it multiple times
it makes no difference
and have had to resort to disabling the 2.4ghz radio
its an a5 revision btw
my release rt-ac88u thats in router mode is working fine (think its a2)
