What does it mean?
SeCrEt BoY™
HTML:
Apr 12 02:41:26 kernel: pgd = ffffffc024892000
Apr 12 02:41:26 kernel: [00000000] *pgd=00000000248b7003, *pud=00000000248b7003, *pmd=0000000024ab6003, *pte=0000000000000000
Apr 12 02:41:26 kernel: CPU: 1 PID: 17396 Comm: dcd Tainted: P           O    4.1.27 #2
Apr 12 02:41:26 kernel: Hardware name: Broadcom-v8A (DT)
Apr 12 02:41:26 kernel: task: ffffffc034294b40 ti: ffffffc024f90000 task.ti: ffffffc024f90000
Apr 12 02:41:26 kernel: PC is at 0xf6f34f44
Apr 12 02:41:26 kernel: LR is at 0x1dc74
Apr 12 02:41:26 kernel: pc : [<00000000f6f34f44>] lr : [<000000000001dc74>] pstate: 600e0010
Apr 12 02:41:26 kernel: sp : 00000000ffb22808
Apr 12 02:41:26 kernel: x12: 000000000009ff10
Apr 12 02:41:26 kernel: x11: 00000000f61ff024 x10: 00000000000a02b4
Apr 12 02:41:26 kernel: x9 : 00000000f61ffb20 x8 : 00000000000a076c
Apr 12 02:41:26 kernel: x7 : 00000000f61ffb50 x6 : 00000000000a0766
Apr 12 02:41:26 kernel: x5 : 0000000000000000 x4 : 00000000f61ffb04
Apr 12 02:41:26 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Apr 12 02:41:26 kernel: x1 : 000000000007c674 x0 : 0000000000000000
My GT-AC5300 keep on showing this in log. I dont know what it is. Anyone have experience about this please help me.
HTML:
https://www.snbforums.com/threads/t...ror-xx-in-my-logs-now-what.55950/#post-478271
Read your topic but finally dont understand... Thanks so much for help. Is it a hardware faulty?
My log dont have dnsmasq line...
You really should use search (dcd tainted) instead of posting a new thread for a known issue which is documented in the changelogs too. ;)
Thanks so much. I am doing searching right now :( Sorry about duplicate a topic... Just because the log is so long and I dont know where to start... Now I thinks it is caused by my PC connect both Wired and Wireless.... After disconnect Wifi and it stop show logs right now. Testing and will join your topic later *^^*
Again, thanks so much man!
Thanks so much. I am do searching :( Sorry about duplicate a topic... Just because the log is so long and I dont know where to start... Now I thinks it is caused by my PC connect both Wired and Wireless.... After disconnect Wifi and it stop show logs right now. Testing and will join your topic later *^^*
https://www.snbforums.com/threads/release-asuswrt-merlin-384-9-is-now-available.54843/
See the info in that first post in the link above.
Are you running an RT-AC86U? Are you using the TrendMicro options in the router? Then we just need to wait for them to fix this code as it is closed source.
Ya... I am using GT-Ac5300 and AiProtection on (I didn't use to turn it on but somedays ago I found that some china hacker try to scan my network and do bruteforce attack...)
And I dont use RMerlin firmware on this AC5300...
The issue isn't with RMerlin firmware. ;)
This is an Asus issue.
If you do use RMerlin's firmware though, you would have access to great scripts that would further protect you from such activity, including Skynet and others. :)
Thanks. Further more, do you use TrendMicro option? It is really need for prevent attackers from outside?
Skynet. Go read that thread for a little. ;)
