I run a master server from a HDD,set as removable in bios,works perfect,all gaming servers connect to it share data etc,website also works.
To achieve this I use xampp,also on the same HDD.
Hard wired into RT-AC5300 and given a static IP within the network and as said works fine with no problems.
BUT
If I boot up the PC with the HDD disabled,wait for bootup to finish then enable the HDD.
No data gets 'forwarded/exchanged' and website is not online.
Where is it failing?
Is there a service that fails to start once HDD is enabled again?
BUT
