Hi All. Is the new UniFi U7 Pro likely to have better coverage through my house or is the Asus RT-AX86U already tough to beat?
Context: I currently have an AX86U which Is great, but there is one room in the house (my son's bedroom) that gets circa -75dBm signal, which results in the wifi in that room being very unreliable. The house is in the UK and over 100 years old, so many walls are solid brick. Wifi wasn't an issue when my son was young, but now he plays on his switch and iPad in his room and gets constant problems. It is a difficult room to get an Ethernet cable to and I don't really want to do an access point with a wireless backhaul (ping times for Fortnite!).
I'm considering getting a Unifi U7 Pro to connect to the AX86U with the AX86U's wifi radios turned off and mounting the U7 Pro in the same location (wall mounted). But the U7 Pro needs to be able to have better coverage and reach the room where there is an issue. I'm aware I'll only have 1GbE to the U7 Pro, but that isn't an issue for the short term as it will future proof things - I'm already using the 2.5GbE port on my AX86U for the 1.2Gb internet connection. I'll probably get a router with more than one 2.5GbE port down the line.
Thanks.
Thanks.
