Only the ones that have previously been discussed with you, namely you changing the IP subnet.Is there any factory setting in Asuswrt-Merlin that could possibly have messed up the file and printer sharing in my home network?
No, I did not. And since the whole thing virtually collapsed, is there a way to reset whatever configs and caches there might be related to networking without reinstalling the OS(es)?Did you modify the IP address in http://router.asus.com/Advanced_LAN_Content.asp before FR the router?
If you did, maybe there are some configurations in your printer and file server that have the old IP
Because you changed the IP address range. Have you checked the Windows PC's to ensure Network Discovery is still active, that the Network Profile is set to Private and not Public? Its possible the Windows network adapter Network Profile got set to Public when it connected to the new IP address range, especially if you are connecting to the local network using WiFi.I have, as I mentioned elsewhere, changed my subset from 192.168.0.x to 192.168.1.x, which seems to have caused numerous issues, though.
Yes, I have checked that.Because you changed the IP address range. Have you checked the Windows PC's to ensure Network Discovery is still active, that the Network Profile is set to Private and not Public? Its possible the Windows network adapter Network Profile got set to Public when it connected to the new IP address range, especially if you are connecting to the local network using WiFi.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
