Wireguard Server on my Network - Can I split the OpenVPN tunnel on AC86U to create a double-hop VPN?
  • Thread starter Thread starter Chris_J
  • Start date Start date
C
Chris_J
Guest
I'm trying to achieve a particular setup as follows:
Wireguard Client -> LAN Network -> VPN Service on router (NordVPN) -> Internet
I believe this is called a double-hop VPN, allowing a client to securely access my LAN but also route any outbound traffic over a commercial VPN provider.
So far, I have set up a Wireguard server, which works beautifully and I can successfully access my home network from outside. I now would like all outbound traffic for any client on the WG VPN to be routed over the VPN client running on the router. My instinct was to add the WG server to the VPN client config page, but once I do this, I can no longer connect to the WG server. I presume this happens because it is also filtering the inbound traffic, which prevents the WG connection (perhaps Nord have the WG port closed).
Is there a way to split the tunnel on the router and only allow outbound traffic to flow over this for a particular device? Or am I barking up the wrong tree entirely here!?
