WireGuard VPN Server Resetting | BT10
Mikep976
Hey Folks,
Curious if anyone else has seen this behavior.
I've had two BT10's running pretty well for the past 3 months. Have 1Gb ethernet to the house, and both nodes are ethernet backhaul connected and set up for this use.
Have been seeing this issue though of, upon setting up a WireGuard server on them, the connection works perfect, as long as I don't reboot the routers in some way. When one or both nodes are rebooted, due to an update or just wanting to give a nice restart to fix some other issue, it seems the WireGuard server "resets" and clients can no longer connect via Wireguard. I've tried re-adding the profile on each client, I've tried the "turn off the WireGuard Server in the GUI and turn it on again" trick, and nothing works. I've also been super careful about all the "Apply" buttons that are needed when setting up. Still though, no use. It also seems to be that the complete configuration in the GUI is reset, as my private keys are completely different on the old config on clients vs in the GUI.
