bobn4burton
OK...so my kids each have a 7" tablet. I get sick of changing out the movies all the time because of limited storage space on the tablets. So I had an idea...what if I just got a wireless router with USB storage port and then I could just get a usb hard drive with all the movies on it and attach it to the wireless router and then just put that in the car for road trips. Then both tablets could just connect up to the router/network share and stream whatever movie they wanted to watch.
They only watch movies in the car and at home...so streaming the movies instead of having them locally on the tablets shouldn't be a problem.
So here are my wants for a router:
1. "Fast enough" USB/HDD read speeds to stream at least two movie streams.
2. I'm not eve sure what bit rate I'm talking about with the movies...but plan to transcode all the movies to either h.264 480p (dvd rips) or h.264 720p (blu-ray rips). Hopefully file sizes will be anywhere from 700meg-3gig for a two hour movie.
3. Again...all movies will be transferred onto the USB hdd via USB on my main computer...so I'm not worried about write speeds. And read speeds just need to be good enough to handle a couple video streams.
4. Obviously wifi range doesn't matter to me.
5. I'm assuming I'll need an N router to handle the video streaming.
6. Hopefully there is a router that will saved the USB hdd mount config so I can detach the hard drive, plug into my main pc and transfer movies, and then re-attach to the router without having to reconfigure anything on the router side (it's OK if router needs to be powered down before disconnecting/reconnecting the USB hdd).
Any thoughts...advice? Will this work very well?
