XT8 - Can't use 20/40/80/160 Mhz on 5ghz channels
sjf99
I'm running RC2-9 but this has been the case since I have this set. My best speeds are when using 40mhz (only). If I also try 80 or 160 (on 5g-2) my speeds are in the teens. My best channel for 5g-2 is 149. For 5g-1 I can only choose from the 4 channels in the 40's. Is there a way to choose the upper channels for 5g-1?
I can provide screenshots of my WiFi configs later (I'm at work).
Any thoughts?
Side note - I did discover that disabling MU-MIMO on 5g-2 resulted in much better performance on that channel.
EDIT - I found some screen shots of my 5-2 channel. I think the only differences are that I disabled MU-MIMO and set the channel to 149. Roaming Assist is also now at -45. Is there anything here you think I should change that may help when having 20/40/80/160 enabled?
