Hi.
I have a mesh setup with 2 ZenWifi AX. AX6600, XT8. Both have now latest firmware 3.0.0.4.386_43170. The problem occured after the upgrade to version 3.0.0.4.386_43169 (ASUS then released the 70-version just a day later) and I upgraded to 70-verion without change. Same problem.
Suddenly, one of my devices (1 year old Lenovo TAB) cant longer connect to the ASUS WIFI. Other devices works fine and the tablet can connect to other WIFI networks.
I have factory resetted the tablet without any change. Tried change WIFI password on the router, changing SSID, adding guest network to connect but no changes. Yes, I have also restarted the two ASUS nodes by powering them off and then on. Also tryed changing the WPA/WPA2/WPA3 setting on the router with all different kind of combinations.
The tablet MAC is not either in some "family blocking", QoS or any blacklist on the router.
In the system log file of the router i get the following trying to enable WLAN on the tablet, choosing the SSID, entering (the correct) password and choose "connect". The 2C:FD:AB:8F:5A
7 is the MAC of the tablet. The WIFI log file is also pasted in this post below the system logfile.
What is wrong???
[LOG FILES ATTACHED AS TXT FILE]
Added: One more device couldnt connect either after update. Samsung S10 Latest firmware and all updates through google play.
What is wrong???
