I have an RT-N66U running the stock Asus firmware. I have the router setup as an access point with both 2.4ghz and 5ghz bands available. I've increased the 2.4ghz radio transmission to 200.
I've found that my network transfer speeds on the 5ghz band are roughly 10x as fast vs. 2.4ghz, even from distances that near the limits of the 5ghz band (ie. on different floor/opposite side of the house). I live in a suburban area - there are some other networks that neighbors are operating but the 2.4ghz band doesn't seem crowded really (I can see maybe 3 other networks and there is minimal, if any, channel overlap with mine on inSSIDer).
At first I thought that the issue was a defective router and so I purchased a 2nd RT-N66U and replicated the same performance issues on the 2.4ghz band. I'm assuming that the issue is interference of some kind, although I am still pretty surprised that the issue is this extreme. Just as an example, since I forget the internal network transfer rates off hand, I am getting something like 30 megabits/s download performance on 5ghz from very far away from the router, whereas from the same location on 2.4ghz I get in the range of 2-3megabits/s.
Does performance degradation this extreme seem consistent with some kind of interference, ie from some other device in my home, or is it more likely that I have managed to get two dud routers?
