[ 3004.388.6 alpha Build(s) ] Testing available build(s)
octopus
Part of the Furniture
Without Microsoft login, hope it's working!?
This is available at this time:
GT-AX11000_PRO
RT-AX88U_PRO
GT-AXE11000
GT-AXE16000
GT-AX6000
XT12
New available 20231221:
RT-AX86U_PRO
RT-AX86U
RT-AX68U
RT-AX58U
New available 20231224:
GT-AX11000_PRO
GT-AXE16000
RT-AX88U_PRO
GT-AX6000
XT12
GT-AXE11000
RT-AX86U_PRO
RT-AX86U
RT-AX68U
RT-AX58U
New available 20231226:
RT-AX88U
3004.388.6 (xx-xxx-xxxx)
- NEW: Added ethtool to the firmware.
- UPDATED: Merged GPL 388_24353.
- UPDATED: nano to 7.2.
- UPDATED: ncurses to 6.3.
- FIXED: CVE-2023-48795 in dropbear.
Let me know when AX88U is getting along with this party
AX88U PRO - Wireguard server doesn't work properly. Server works, client's connection with server works, log on server and client is clear, but internet on client (iPhone 15 Pro Max) doesn't work.
No RT-AX86U? Will it get the 388.6????
These are Alphas. Sit back and let Merlin finish with each model as he gets a chance, time, and required stuff from Asus for each model.
This is aviable at this time:
GT-AX11000_PRO
RT-AX88U_PRO
GT-AXE11000
GT-AXE16000
GT-AX6000
XT12
From the Changelog-NG.txt file:
Anyone else have major wireless issues with this alpha build? On my GT-AX11000 Pro, no devices except 1 laptop wanted to connect and it was only able to access to router, no internet. I reverted and resolved the issue but just wondering if it was just me or the build
No issues here on the GT-AXE11000. As soon as it rebooted I already had 20 clients connected as seen below.
I have same problem on my AX88U PRO.
Are you using WPA3 or WPA2? I'm still using the older WPA2.
Maybe thats the key difference? I'm not sure, just shots in the dark here.
I'm using WPA3/WPA2 mixed mode. Are you using DNS-over-TLS?
P.S. My LAN clients have access to router, and don't have access to internet. I think the problem in DNS.
Web SSL is broken in this Alpha, any https sites does not resolves. This is probably related, the self certificate is stuck in authorizing.
GT-AX6000
This is just a visual quirk, because Asus reworked the way the router's SSL certificates are generated and handled. Go to the Administration->System page, and click on the button to Renew Certificate. It will generate a new one that uses the new standards, and will also save it to the new storage location so the webui can report its information.
This is totally unrelated to accessing https sites.
I see WIFI drivers are updated as well.
I afraid it would brake here everything
Will see how Alpha rolls and when my model gets treated as well
If you have wifi issues, try power cycling the router to reset the chip.
On the GT-AXE16000 it's working fine for me.
I was going to re-install alpha1 to regenerate the certs but if the https sites is a different problem then I'll wait for the next version.
Your HTTPS issues have nothing to do with the router. HTTPS is just traffic over port 443.
