AC-86U High Temperature (90 C)
Craytz43
Hey,
Recently I noticed some problems in my Wifi,
I looked a bit , and noticed the the Temp is quite high - IS IT NORMAL?
Its currnetly 30 C inside my home.
Is there a solution that I can do?
** freshly rebooted- and restored to default - after fresh install of latest merlin
That's about normal for that model. My RT-AC68U (a different model) had the same temperatures also.
Confirming normal for this model. Your home temperature is quite high though.
If the temperature gets closer to 100°C the CPU will start throttling and one core will shut down crippling the overall performance.
I had in the past issue with stability when AC86U temperature was above 85C - I just added on back 120mm USB fun. And do not keep in in close space.
It non need to be issue with CPU or wi-fi direct if you have such big temperature inside different components that are not monitored can be unstable.
you did not wrote what issues you have with wi-fi?
recently I bought a mi box streamer, and got 120 mb at the beginning , then something happened the last week , very week results , not stable. below 20mb , I got 500 mbit overall.
