I'm currently on a 200Mbps Fibre. Using the Asus RT-N66U with WAN connected to the ONT, my iPTV set top box is connected to port 4 (VLAN) using a long ethernet cable. Btw, my new setup will still have Ethernet cable (restriction). I have 2 SSIDs, one each for 2.4GHz and 5GHz.
New Setup
I bought a new Asus AC87U to replace the RT-N66U.
I want to place the RT-N66U next to my set top box and to increase my wireless coverage near to the setup box.
Though option 1:
Will this work?
ONT->AC87U WAN port->AC87U Internet port 1 connect to RT-N66U WAN port->RT-N66U Internet port 4 connect to setup box (VLAN configuration as above).
On the RT-N66U, set to AP mode.
Though option 2:
ONT->AC87U WAN port->AC87U Internet port 1 connect to switch->Switch port 1 to RT-N66U WAN port->RT-N66U Internet port 4 connect to setup box (VLAN configuration as above)
For using the RT-N66U to extend Wireless coverage, any advice on how to do that?
1. SSID 1 - 2.4GHz (N)
2. SSID 2 - 5GHz (N)
3. SSID 3 - 5GHz (AC) - new to AC, is this workable or I should just stick to SSID 2 on 5GHz?
New Setup
Though option 1:
Will this work?
Though option 2:
