RMerlin
Asuswrt-Merlin dev
...I built an RT-N66U firmware that uses the SDK6 driver. This is the same driver as used by the RT-AC66U (without the 802.11ac support, obviously). This is highly *EXPERIMENTAL*. I only tested it for a bit to ensure that it was at least allowing my laptop to connect to it, and that channel configuration worked.
The version can be found on Mediafire in the Experimental folder for the RT-N66U.
Just to be safe, make a backup of your configuration before flashing!
I'm interested in hearing about:
- Wireless performance (please do an actual file transfer test - the link speed is half-meaningless as power management can make it go up and down based on traffic)
- Are you having better or worse success in connecting to the 5 GHz band (please specify the model of your wireless adapter)
