Asus AX11000 Pro - Eth1 getting frequent connection drops
um hombre
I am on the latest firmware from Asus but I was having the same issue on previous firmwares as well.
My PS5 keeps getting connection drops (Lan disconnected and connected back a second later). It used to happen once in a while and I have just experienced 3 occurrences within minutes.
Here is the log extract:
May 16 17:37:14 wlceventd: wlceventd_proc_event(568): eth6: Assoc B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
May 16 17:37:19 kernel: eth1 (Int switch port: 3) (Logical Port: 3) (phyId: 4) Link DOWN.
May 16 17:37:21 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind B0:4A:39:4B:35:13, status: 0, reason: Unspecified reason (1), rssi:-35
May 16 17:37:21 wlceventd: wlceventd_proc_event(539): eth6: Auth B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
May 16 17:37:21 wlceventd: wlceventd_proc_event(568): eth6: Assoc B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
May 16 17:37:22 kernel: eth1 (Int switch port: 3) (Logical Port: 3) (phyId: 4) Link Up at 1000 mbps full duplex
May 16 17:37:28 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind B0:4A:39:4B:35:13, status: 0, reason: Unspecified reason (1), rssi:0
May 16 17:37:28 wlceventd: wlceventd_proc_event(539): eth6: Auth B0:4A:39:4B:35:13, status: Successful (0), rssi:0
May 16 17:37:29 wlceventd: wlceventd_proc_event(568): eth6: Assoc B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
May 16 17:37:36 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind B0:4A:39:4B:35:13, status: 0, reason: Unspecified reason (1), rssi:0
May 16 17:37:36 wlceventd: wlceventd_proc_event(539): eth6: Auth B0:4A:39:4B:35:13, status: Successful (0), rssi:0
May 16 17:37:36 wlceventd: wlceventd_proc_event(568): eth6: Assoc B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
May 16 17:37:49 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind B0:4A:39:4B:35:13, status: 0, reason: Unspecified reason (1), rssi:0
May 16 17:37:49 wlceventd: wlceventd_proc_event(539): eth6: Auth B0:4A:39:4B:35:13, status: Successful (0), rssi:0
May 16 17:37:49 wlceventd: wlceventd_proc_event(568): eth6: Assoc B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
May 16 17:37:56 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind B0:4A:39:4B:35:13, status: 0, reason: Unspecified reason (1), rssi:-35
May 16 17:37:56 wlceventd: wlceventd_proc_event(539): eth6: Auth B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
May 16 17:37:56 wlceventd: wlceventd_proc_event(568): eth6: Assoc B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
May 16 17:38:00 kernel: eth1 (Int switch port: 3) (Logical Port: 3) (phyId: 4) Link DOWN.
May 16 17:38:02 kernel: eth1 (Int switch port: 3) (Logical Port: 3) (phyId: 4) Link Up at 1000 mbps full duplex
May 16 17:38:03 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind B0:4A:39:4B:35:13, status: 0, reason: Unspecified reason (1), rssi:0
May 16 17:38:03 wlceventd: wlceventd_proc_event(539): eth6: Auth B0:4A:39:4B:35:13, status: Successful (0), rssi:0
May 16 17:38:03 wlceventd: wlceventd_proc_event(568): eth6: Assoc B0:4A:39:4B:35:13, status: Successful (0), rssi:-35
Any ideas?
