ASUS RT-AC66U Firmware version 3.0.0.4.372
Discussion in 'ASUS AC Routers & Adapters' started by janosek, Jul 12, 2013.
  1. janosek
    janosek Regular Contributor
    Jan 8, 2013
    146
    (Select Windows 7, 64 bit OS to see the page)
    Fixed:
    1. Fixed AiCloud vulnerability related bugs.
    2. Underline "_" can now be acceptable in device name and computer name.
    3. Hide Broadcast option in PPTP VPN server when it is disabled.
    4. Fixed multicast IPTV related issues in PPPoE/PPTP/L2TP connection.
    5 .Fixed parental control offset issue in IE.
    6. Fixed 3G dongle related issue.
    7. Hide ASUS DDNS description when selecting 3rd party service.
    8. Fixed script error 'invalid argument on IE'
    9. Fixed smart sync JS error
    10. Fixed JST time zone issue.
    Added:
    1. Upgraded the wireless driver and supported 5GHz explicit Tx beamforming.
    2. Disk scan feature. It is in external USB disk status tab in network map.
    3. Support Sandisk Cruzer flash drive with both CD-ROM and flash disk interface.
    4. Auto adjust time zone in internet setup wizard process.
    5. PPTP VPN server status GUI
    6. Recognized .rmvb files as video format in media server.
    7. Show more detail information in USB application install process.
    IPv6
    1. Fixed PPP IPv6 global address retrieval
    2. added DHCP-PD option
    3. Added LAN DHCPv6 server
    4. Added network status GUI.
    5. Added option domain name if available
    3G/4G dongles
    1. Support Yota LTE dongle LU150
    2. Support ZTE LTE dongle MF821
    3. Support 3G dongle Q110
  2. Log in / Register to remove this ad
  3. Grievous Angel
    Grievous Angel Regular Contributor
    Jun 16, 2013
    99
    I'm assuming Merlin's build is based upon this release, based upon the version number, so I'll stick with his. I'm enjoying my cron jobs.
  4. cmillar6
    cmillar6 Senior Member
    Feb 26, 2013
    292
    Merlins build is based on older code, I expect he will release a new .372 version when time permits. This build fixes the AI cloud vulnerability.
    I just uploaded it and I can confirm the ping issue with wired clients is resolved.
  5. DaveMishSr
    DaveMishSr Very Senior Member
    Jul 14, 2012
    530
    San Diego
    Merlin posted in Asuswrt-Merlin forum that this release is based on newer code than his 372 release. He is busy at work so even after Asus releases the source code it will be a couple of weeks at the earliest before he can update his version.
  6. roscolo
    roscolo Regular Contributor
    Apr 4, 2013
    93
    Nope. As of 4:30pm EDT today, the most recent firmware I see on the RT-AC66U when I select "Windows 7, 64bit" or "Windows 8, 64bit" is still 3.0.0.4.354. I have to select literally any other OS than "Windows 7, 64bit" or "Windows 8, 64bit" to see or download 3.0.0.4.372 Weird. Think I will hold off for now as I am running Windows 7, 64bit.
  7. cmillar6
    Feb 26, 2013
    292
    The firmware release has nothing to do with the operating system, only the utilities
  8. roscolo
    Apr 4, 2013
    93
    Got it. Why do you suppose Asus appears to have gone out of their way to specifically not have the new firmware 3.0.0.4.372 available under "Windows 7, 64bit" and "Windows 8, 64bit"?
  9. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    16,678
    Canada
    Probably a mistake from their webteam I suppose.
    I always went to "Others" myself whenever looking for FW or GPL updates, so no idea if that's the norm or just unusual.
  10. cmillar6
    Feb 26, 2013
    292
    This is the first time I have run stock firmware since purchasing my AC66u, it seems so stripped down compared to Merlin's , it will be a long two weeks :(
  11. roscolo
    Apr 4, 2013
    93
    Well, as of 6:17pm EDT, if you click on "Others" the 3.0.0.4.372 firmware is not there either.
  12. RMerlin
    Apr 14, 2012
    16,678
    Canada
    It still shows for me. Could be they have a cluster of servers and not all of them are up-to-date.
  13. cmillar6
    Feb 26, 2013
    292
    neighbor table overflow errors are no longer showing up when running ipv6, liking this new code so far.
  14. roscolo
    Apr 4, 2013
    93
    Yep. 3.0.0.4.372 shows for me me, too, now, under all OS's and Others. When I check for updates from within the RT-AC66U menu screen it still shows 3.0.0.4.354 as being the latest version. I guess that will change after a little while, too. Thanks to the OP for the heads up on this.
  15. master wolfe
    master wolfe New Around Here
    Apr 23, 2013
    7
    Still getting those here in Panama City Beach with what shows as 3.0.0.4.372_1300
  16. pepemosca
    pepemosca Occasional Visitor
    Apr 11, 2013
    29
    And how did RMerlin got a newer 372 version?
  17. RMerlin
    Apr 14, 2012
    16,678
    Canada
    It's the other way around. My 372 code is two months old. This release from Asus has much newer code.
  18. maylyn
    maylyn Regular Contributor
    Dec 24, 2012
    76
  19. maylyn
    Dec 24, 2012
    76
    Please feedback on the 5GHz on this firmware, since it's using the newer wireless drivers based on the changelog :D Thanks
  20. DaveMishSr
    Jul 14, 2012
    530
    San Diego
    Reload the page. I had the same problem. As soon as I reloaded the page I could then see the 372 firmware version. Another solution is to clear the cache for whatever browser you are using.
  21. Raptor
    Raptor Occasional Visitor
    Mar 9, 2012
    39
    New ASUS .372 driver test.
    So far my experience with this driver has been negative. I have a certain location that I test from so that I can easily compare changes. Model used is RT-AC66U at 5GHz with a Killer Wireless N 1103 Notebook adapter. Using inSSIDer and downloading from my NAS.
    .354 driver Signal strength -48 dBm
    .372 driver Signal strength -56 dBm
    This signal drop was consistent at other locations in the house. I went back to .354 and the signal went back to -48 dBm. The new .372 driver drops the signal about 8 dBm.
    Downloading large 8GB file from my NAS. Version .354 was 24 MB/s, switched to .372 it was 19 MB/s. Tried this 5 times with each build and it was consistent.
    Merlin's current 372_2 build performed the same as .354
    Note: iPad 2 connects to 5GHz with .354 but will not connect with Asus .372. All three of my kids complained that the Internet was choppy and slow on there iPods and iPhones when I was testing the new .372 driver. When I switch back to .354 or Merlin .372_2 build everything was back to normal.
    I recommend staying with build .354 or Merlin build .372_2
    Thanks!
Share This Page
