Hi folks!
I am seeking advice on expanding the wifi network from a 4g device. Thanks to Comcast lying about my service area, my newly purchased home does not have a landline high speed connection. However we do get acceptable 4g.
What would be the best way to expand the wifi from the 4g device house wide? It is a large home. My original plan was to use a hotspot and a couple of routers to repeat the signal. I ordered a netgear r7000, and I was going to use my wndr3700 in repeater bridge mode (ddwrt), but the chipset does not support it. I will have two areas of fairly high usage of wired connections (office and living room). I might be able to connect these via cat6 eventually, but would prefer to use something wireless for now (attic heat in southern USA in June is no good ).
The hiccup with the wdnr3700 has made me realize there's about 100 ways to approach this, and I need some better information / planning.
What are you opinions / suggestions on these options?
1. wifi hot spot, Router A as repeater bridge, Router B as repeater bridge (can multiple "repeater bridges" be used? - I don't know what functions are lost using routers in repeater mode)
2. wifi hot spot, Router A as repeater bridge, wireless extender
3. wifi hot spot, Wireless adapter, Router A as normal router, option 1 or 2 above
4. wifi hot spot, 2x wireless extender
5. Ditch hot spot for a 4g router with sim card slot? (just found out about these. combine with solution above?) (lose portability for features)
6. Get usb modem + router, use extender above?
7. Whatever awesome option you are about to tell me about
For some reason, the thought of seeing if someone made a 4G router never came to me until today. Right now I am thinking my best bet would be to get a cradlepoint or mofi router with a usb modem and then use an extender or a router in repeater mode.
Can I daisy chain devices? like have first router at front of house, an extender in the middle and then another extender/ router (something I can plug devices in) in back of house? (about 80-100ft and 2-3 brick walls between points depending on where I place them).
Some of the devices I'm looking at (not all at once of course!):
Peplink Pepwave MAX BR1
pantech 290
Cradlepoint MBR1400
MOFI3500-3GN Version 2 Rev 2
Netgear ex6200
Netgear r7000
Thanks!
pantech 290
Cradlepoint MBR1400
Netgear ex6200
Netgear r7000
Thanks!
