zyu4router
Currently the both AC router and AC network card are marketed with combine total speed it can get from both 2.4 GHZ and 5Ghz. Namely if router or network card marketed as AC1200 it means it can get max speed from 300mbps (2.4ghz band) and 876mbps (5ghz band) to archive near 1200mbps.
However, I never be able to connect both 2.4ghz band and 5ghz band at same time. I can either connect to 2.4ghz band or 5ghz band.
Is that possible to connect to both bands at same time to maximize the speed?
OR
It is just a marketing thing? in real life, we cannot connect both bands at same time to aggregate speed?
OR
