Voxel Custom firmware build for R9000/R8900 v. 1.0.4.68HF
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-66hf.83325/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-67hf.84135/
New version of my custom firmware build: 1.0.4.68HF.
Changes (vs 1.0.4.67HF):
1. Toolchain: GCC is upgraded 12.2.0->13.1.0.
2. Toolchain: Go is upgraded 1.20.2->1.20.3.
3. tcpdump package is upgraded 4.99.3->4.99.4 (fixing CVE-2023-1801).
(score 6.5, Medium)​
4. libpcap package is upgraded 1.10.3->1.10.4.
5. libgcrypt package is upgraded 1.10.1->1.10.2.
6. libgpg-error package is upgraded 1.46->1.47.
7. libnl-tiny package is upgraded 2022-11-01->2023-04-02.
8. curl package is upgraded 7.88.1->8.0.1.
9. coreutils package (sort/gnu-date) is upgraded 9.1->9.3.
10. e2fsprogs package is upgraded 1.46.6->1.47.0.
11. ffmpeg (minidlna) package is upgraded 5.1.2->5.1.3.
12. busybox: enable COMMAND_SAVEHISTORY for shell.
13. Remove libxml2 (unused).
14. wget: remove libpcre dependency.
15. readline: split to 'libreadline' and 'libhistory', disable 'libhistory' in 'defconfig' (unused).
16. Selective optimization '-O3' of kernel components/drivers (slight boost).
17. Host tools: upgrade xz to 5.4.2.
18. Host tools: upgrade squashfs4 to 4.6.1.
19. Host tools: upgrade mkimage/u-boot to 2023.04.
20. Host tools: upgrade e2fsprogs to 1.47.0.
21. Host tools: upgrade mpc to 1.3.1.
22. Host tools: synchronize squashfs3-lzma and lzma-old with OpenWRT.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
I have an issue, I have two switches attached to the router. A gigabit (Netgear ) and a 2.5 with 2 10gbs port (Qnap) The link speed between the Nexgear x10 router and the switch drops speed from 1000mps to 100mbps. Reverting back to V1.0.4.67HF rectifies the issue. I have tried three times with the same result every time.
Does the link speed connection drop for both switches or for just one? If just one, specifically which one?
Working great so far, I'm looking forward to the next build!
Any ETA on the next one?
