Customize Minidlna settings
RebelAngel
Dear Forum - is tere any way to customize the settings of the Mini dlna server? Specifically I would like to disable the album art resize or at least set it to a higher value than 160x160 - if possible.
Maybe start with the following from the Asus-Merlin Wiki to see if anything there gets you started:
Minidlna: Common Issues & Solutions
Its several years old so it may be out of date.
I don't think this is possible, short of going in after the fact and either replacing the 160x160 art-cache file with one of higher resolution or modifying the SQL database to point to a higher resolution image file. The 160 resizing step is hard-coded into metadata.c. I do run a "fix" script every day to modify some of the SQL database content (like fixing date formats and swapping artist with album artist) to make it more compatible with my media player app, but image is not one that I've messed with.
