[Dev][Feedback] Changing DNS behaviour on router
RMerlin
Asuswrt-Merlin dev
Heya,
I am considering reverting back resolv.conf to match what Asus uses in stock firmware, which is to always use the DNS servers rather than 127.0.0.1 (which means always use dnsmasq). Primary reason would be this might be more robust for weird ISPs who use a DHCP + VPN type of architecture (as after the DHCP lease is obtained, it typically uses a special "temporary" DNS server that can resolve the ISP's PPTP/L2TP hostname).
The primary side effect of this is the router itself will no longer be able to resolve LAN hostnames. The most visible effect for end user is netstat-nat (on the webui) would no longer resolve LAN IPs into LAN hostnames (but it would still work for public hostnames).
Any impact on the existing scripts out there that are run on the router itself? Does any of these require to be able to resolve LAN IPs and hostnames?
This is a little above my pay grade, but, here goes.
Would this change be the same as having dns filtering=on, & global filter mode = router?
(Without any custom dns necessarily specified).
This change would not affect LAN clients resolving hostnames (internal or external). Just when the router itself wants to resolve a hostname (e.g. for firmware update check).
Hi...
Just curious... how many of us are using those weird ISP's services ?
Hi...
Not many. The only ISP I heard of is Beeline in Russia.
Just for my understanding: It would not be possible anymore to check with a script on the router if a specified decive hostname is resolvable/reachable?
While I don't pretend to fully understand the impact of RMerlin's proposal, I have a question. How would this impact the use of the etc/hosts file for local name - IP resolution? I sometimes use that mechanism to override DNS lookup.
That's a separate issue. On older models it won't make any difference. HND models however (RT-AX88U and RT-AC86U) will require a separate fix to make these works properly. That's stricly for router-based resolution however, your LAN clients going through dnsmasq will still behave 100% like before.
It will mostly affect name resolution. You can still use a device's IP to ping it, for instance.
I'd also keep the current design which allows local name resolution within router cli and scripts. I'm using names in some scripts for devices with dhcp addresses in my lan.
If that's the case, I would keep the current design option and not align with ASUS, because I'm quite sure that such a modification may break a significant number of our current setups.
can you give any example of such setup please?
If you use nslookup, you can also specify a nameserver to use (in your case, 127.0.0.1).
