How to fix a little issue with a RT-AC66U
Angelboy
I am using Operation Mode:Media bridge Firmware:3.0.0.4.372.30_2 (Merlin build)
Connected to a wifi 2.4 AP on fiber Internet.
The AC66 then use the 5g and cable to clients.
Everything works perfectly except 2 tings ....
Nr one :
I get a lot of this all the time ..
Jul 11 02:19:26 kernel: eth1: received packet with own address as source address
Nr two :
I get a disconnect to the 2.4 randomly (every 0.5 -4 hours or so) but the router interface says everything is ok
Anyone have a tip to fix this ? All help is greatly appreciated
Nr one :
Nr two :
Nr. one was already discussed serval times in the forum - do a small search and you get some hints on it...
But basically it's still not solved, nor does it do really any harm. :rolleyes:
Nr. two is not so easy to find out, but I would put attention on the WLAN channel used to avoid to much interferences with other WLANs in your neighborhood - I had a similar issue in the past. :eek:
With kind regards
Joe :cool:
Ty for answering, you where landing on the same answers I have found, but ok then we just have to w8
Jul 17 04:37:21 kernel: eth1: received packet with own address as source address
Jul 17 04:37:29 kernel: printk: 14 messages suppressed.
Jul 17 04:37:29 kernel: eth1: received packet with own address as source address
Jul 17 04:37:38 crond[309]: time disparity of 1336417 minutes detected
Jul 17 04:37:41 kernel: eth1: received packet with own address as source address
Jul 17 04:37:54 kernel: eth1: received packet with own address as source address
Jul 17 04:47:21 kernel: eth1: received packet with own address as source address
Jul 17 04:47:22 kernel: eth1: received packet with own address as source address
Jul 17 04:55:55 kernel: printk: 2 messages suppressed.
Jul 17 04:55:55 kernel: eth1: received packet with own address as source address
Jul 17 04:56:00 kernel: eth1: received packet with own address as source address
Jul 17 04:56:05 kernel: eth1: received packet with own address as source address
Jul 17 04:56:10 kernel: eth1: received packet with own address as source address
Jul 17 04:57:21 kernel: eth1: received packet with own address as source address
Jul 17 04:57:22 kernel: eth1: received packet with own address as source address
Jul 17 06:17:22 kernel: printk: 2 messages suppressed.
Jul 17 06:17:22 kernel: eth1: received packet with own address as source address
Jul 17 15:27:26 kernel: printk: 2 messages suppressed.
Jul 17 15:27:26 kernel: eth1: received packet with own address as source address
Jul 17 15:37:26 kernel: printk: 2 messages suppressed.
Jul 17 15:37:26 kernel: eth1: received packet with own address as source address
