smcgrath12
Hello, I am wondering if there is a way to run a third instance of OpenVPN on RT-AC68R running the latest Merlin build? If it is possible, can someone describe what files I need to create & modify to accomplish this? I searched the web and couldn't find anything. I figured if there were some instructions to setup OpenVPN manually (w/o using web UI), I could use those to manually set up a third instance, but alas, nothing that I could find. Thank you.
