[Preview] Asuswrt-Merlin 380.64 test builds
RMerlin
Asuswrt-Merlin dev
Test builds were uploaded to Mediafire.
Not many changes at this point, this is mostly to start testing the new firmware notification scheme.
Please keep the feedback specific to the new update notification in this separate thread.
Changes since 380.63_2:
19757f7 rc: Only enable live update if MERLINUPDATE is enabled, otherwise the webui Check button will lead you to the support site
d4d5d1e Updated documentation
858d792 fwupdate: fix filename of beta release notes
53491c8 fwupdate: set update server address in nvram
15c22d0 build: Fix makefile logic for FW and BWDPI sig upgrade, make sure we copy sig scripts with merlinupdate enabled
bdc28f8 build: remove MERLINUPDATE from target profiles, so it can be passed at build time
006b96e Bumped revision to alpha 2
79dbfab Updated documentation
c43d024 webui: Report error if importing an ovpn file with a missing/invalid key or certificate.
e506192 httpd: Fix httpd crash when importing ovpn file with an invalid key/cert
36a9d91 fwupdate: disable it in the public target.mak profiles so forks/derived builds won't have it enabled by default
bb7fdbf fwupdate: Switch manifest and changelog to .txt extensions.
f593784 webui: Display notification if free nvram < 3000 bytes, which can lead to stability issues (based on john9527's code)
9a6c5c2 iptables: revert Asus fix so we can now parse a --set-mark mask following the previous commit
6b6e3a1 iptables: support  --set-mark mark[/mask] on MIPS routers
bd44afd docs: Refer to the Wiki for the up-to-date list of supported models (closes #1107)
809db69 Updated documentation
e986d76 nano: Updated to 2.7.1
9e3e6af Implement new firmware availability check.
101306d Bumped revision to 380.64 alpha1
Alpha 3 changes:
fb86ad0 Updated documentation
0aeb026 webui: fix App popup for Firefox (and probably other browsers), also resolve JS error on these browsers
065e628 build: fix building with AUTODICT disabled (closes #1102)
1c42870 tor: route other ports than just 80/443 through Tor, and block UDP/ICMP traffic (Closes #1118)
7963b42 openvpn: Updated to 2.3.13
eb23bd6 webui: add link on the FW update page pointing to the enable/disable option on Tools->Other Settings; hide the field if firmware does not support live update
1545ecb webui: have the new FW changelog page point you at your router's model download location instead of the primary landing page
6bf1ac1 Bumped revision to alpha 3
No support will be provided for these early test builds.
Just making sure, the notice that there's an alpha3 available is not the case? Its just testing the update feature?
connecting to OpenVPN server, in sys log appear these messages never seen before:
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #659 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #660 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #661 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #662 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #663 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #664 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #665 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #666 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #667 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #668 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #669 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #670 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #671 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #672 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Nov 27 23:24:49 openvpn[982]: client/5.170.125.148:4107 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #673 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Merlin: 380.64_alpha2 rock solid after 48 hours running on my RT-AC1900P, but I'm not doing anything exotic with it - except passing a lot of IPSEC through it.
Alpha 3 builds have been uploaded to Mediafire.
Successfully updated both RT-AC68U and RT-N66R from Alpha 2 to Alpha 3.
In Firefox for seemingly the past couple firmwares and on all the pages except Traffic Manager, the tabs are separated from the content, example below. A simple margin fix will cure it:
.FormTitle {
margin-top:-100px !important;
Edit: uMatrix was the problem.
alpha 3 working fine on my ac3200
all quiet on the eastern front here
.FormTitle {
http://imgur.com/pSb5EkI
I don't have any problem here with Firefox. Are you using either a small window or custom zoom/DPI?
Changing the CSS with this would break it for everyone else...
Sorry to bother you. I put more time into figuring this out today and uMatrix either enabled or disabled seems to be the culprit; sometimes it works, sometimes not. I thought I ruled it out at one point but guess I didn't. Thanks. Edit: Apparently I had the user-agent option enabled and since it changes every 5 minutes, it's what led to the inconsistency.
do not know if related or not but running alpha 3 or the latest and when I click on my computer the network lists nothing. I have 13 devices on my network and they all function and the ones that I have links for are accessible its just they are no longer listed. and only changes made were the router firmware.
any one else seeing this?
thanks
Alpha 3 up and working well 15 hrs on my 88U.
I think the alpha 4 is a typo, or referring to the fake alpha 4 he post for testing his notifications.
As of posting, I do not see alpha 4.
I think it's a typo .. I found Alpha 3 not Alpha 4 :)
Correct. That's because only a few minutes before posting, I had been spending time with a "fake" alpha 4 entry on the firmware update server, to test the model-specific URL.
