Hi.
i had been using an asus RT-N16 with merlin firmware, it worked ok but i kept getting locked out with some page throwing up something about the settings have changed and you need to reconnect to the network and use new ip addres and port...the only way i could get around this was to have someone reboot the router at its location, not good, i needed open VPN so i have just purchased an asus N66u, it seeme to be fine but again after some hours i cannot connect to the router remotley, i am not getting the same page as before but its basically saying 'connection attempt to XXXXXX.XXXXX.com was rejected. The website may be down, or your network may not be properly configured.' and an error code 'ERR_CONNECTION_REFUSED'
i cant connect to any of the port forwards i have setup either but oddly i have plex running on my UNraid server and is setup with UnPnP and that was getting through ok...not sure where i need to be looking, i have the router setup with a paid DYN account, sometimes i noticed on the main page of router there would be a yellow exclamation referencing the connection to dns saying 'disconnected' but i would still have access to the router remoteley.
What i have noticed is that it seems fine when i am connecting over my phone via 3G, but when i get to somewhere else and it hooks up to a wifi that is when its all stops working, like the ip addres of where my connection is coming from has changed and then it spits out its dummy.
Your help and advice greatly appreciated.
