RT-AC66U Firmware: 380.64_alpha3
Wilsonb
RT-AC66U -
I went to alpha because while I was on
RT-AC3100_380.63_2.trx
I lost the function of showing clients from Main network map section (shows 11) but when clicking on on it it doesn't show any clients and all Static IP listings under LAN-DHCP are gone..
Factory reset to default and from beggining does not work anymore.
Not sure what happened and I understnad how this happend.
Anyone?
Are you using an AC66U or AC3100? These are two very different models...
Did you re-flash and set up from scratch without using a saved configuration file?
Wow, one of the best active forum I have seen.. Thanks
Got it up and running again. Had to do a Hard Reset (hold reset 30sec unplugged / 30 sec plugged) . Not sure what happpend.
AC66U
Yes, had problem even after factory reset. Got it working by doing a Hard Reset
AC66U
I've had to reflash a couple of times to get mine working right, and did an nvram clear, and then it seemed to be okay.
Glad you got it working though. Is it an older AC66U or one of the newer ones?
