RT-AC68U types Firmware version 3.0.0.4.384_32799 for RT-AC68W/P, RT-AC1900/U and RT-AC66U_B1
Grisu
Part of the Furniture
32799 out usable for all RT-AC68U variants
https://www.asus.com/Networking/RT-AC1900U/HelpDesk_BIOS/
https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AC1900U/FW_RT_AC1900U_300438432799.zip
Version 3.0.0.4.384.32799 2018/09/1442.54 MBytes
ASUS RT-AC1900U Firmware version 3.0.0.4.384.32799
Fixed WIFI stability issue.
Please unzip the firmware file first then check the MD5 code.
MD5: 1fd079bd8633106f41a0395fb45c2758
Interesting: came from 32738 with factory reset over dirty Merlin 384.7_beta1 and again dirty back to 32799 and now SSID is not visible, white letters on white background ...
I recently upgraded both of my rt-ac68p routers from 32738, I believe, to 32799 and the wifi stability is still terrible. frequent disconnects, does not transition between 1 router to the next smoothly, etc.. I haven't had good quality wifi in my house in the past few weeks, easily.
I have not performed a factory reset. is this required after each router firmware upgrade? if so, that's pretty annoying!
I sent feedback via the feedback button within the router gui. @arthurlien
thanks!
There is nothing significant between 382 and 384 that would mandate a change, the 380 to 382 update did change some variable names however.
The 68U release notes appear to document significant changes within 384. If one does not reset and does have issues, then it is advisable to then reset. Or, you could just reset to begin with. For me, insisting I don't need to reset because I thoroughly understand the firmware development is not an option because I don't.
OE
