triglia118
Dear friends, I have a problem and I need some help.
I own 2 RT-N66U, one at my place and the other at my parent's place. Both of them use Merlin 376.45 firmware. I connected them successfully via VPN TAP and everything works. My parents use RT-N66U as DLNA server. The media storage is a usb connected HDD.
Long story short:
At the beginning I used it formatted in NTFS with firmware's DLNA server: a lot of problems (every re-boot Minidlna starts media scanning again, unreliable media access etc..). Then I installed the new Minidlna version through Entware using a EXT3 microSD card in the internal bay of the router (internal storage for Entware Debian and Minidlna, external NTFS usb disk for multimedia content): far better, but still experiencing random stop in streaming.
Yesterday, after reading the forum, I tried to empty the external multimedia storage, and re-format the disk in EXT3, then transferring back multimedia content from my parent's PC to the disk, using network. Everything seems good, but it's too early for a feedback for the streaming issues.
But I experienced a new problem.
Now I'm not able to write to the external EXT3 disk from my place using VPN: I can read the content but not write nor modify it. At my parent's place, using their PC I can r/w without problems (via lan). I've already checked samba permissions, user names and tried the console command: chmod -R 777 /tmp/mnt/Archivio but it seems that at my place all shares's subdirs are read only. I also tried to change Win7 permissions after allowing guest share access, but I'm stuck in the same situation described here: http://forums.smallnetbuilder.com/showthread.php?t=9196
In samba settings user names and permissions are the same for both routers.
Please help me, and keep in mind that I'm a noob in Linux as I'm in English (sorry). Thank you for your time.
Long story short:
