Parker Woolfol
Hello all,
I was looking at getting a 2 gig up/down connection through comcast and I had thought of the solution of link aggregation or using doubleshot pro to combine Ethernet/wifi etf to get more than the 1gbps an individual lan port provides, but it dawned on me that the WAN port might also be 1Gbps and i'd be limited there anyways. The research i've done says the router rupports up to 1800mbps WAN-LAN, I believe thats my answer but it doesn't say how. I've never heard of going from a 1gbps ethernet to 2, just 1 to 10gbps. Can someone tell me if i'm right and how this would be accomplished? I'm thinking maybe its using dual wan 1 gbps connections? and if so would that work if the dual is actually 1 isp? Your thoughts and opinions are greatly valued, thanks!
