johndoe85
Surely you dont need a diagram for this. It's the most simplest solution.I'm sorry, I don't understand that 10Gb home network you are planning to build with one switch and one access point. Draw a diagram of this network the way you see it, from the ISP equipment to your eventual clients. List what equipment do you have available and what you intend to add or replace.
I have internet, a fiber konverter (which i btw might change the SPF+ connectors of to gain more speed without my ISP knowledge. If i go maximum bandwidth they can offer.)
I then will have to bypass the fiberconverter and put it somewhere else, i imagine a switch is sufficient. Probably a manageble one.
An Accesspoint added to that and i have WiFi connection too (for my wifi devices such as cellphone)
The rest, RJ45 to switch.
This is my idea, where are the flaws? Please point them out
