2.4GHz network stops with RT-AX56U as Mesh Node
MatynK
I have just upgraded my AC68U to a AX56U, all seemed to work fine at first, but then I find that a number of 2.4GHz devices can no longer connect to the internet.
My original configuration has a AX88U as the main router and the AC68U as the node which worked fine, swapping the old AC68U back seems to get things working again.
I have tried the disabling "802.11ax / Wi-Fi 6 mode" when the AX56U is running but that did not seem to make any difference.
Its configured to use a wired backhaul as the wifi signal between the two is not brilliant.
Anyone have any ideas ?
