freddie802
I have a RT-N66U configured as a repeater using the 5Ghz band to connect to the main router. I am having issues with devices connected to the 2.4Ghz band on the repeater. It will work for a day and then the clients lose connectivity to the repeater. I have to power cycle the RT-N66U in order for them to reconnect again. As a matter of fact the clients need to reenter their wpa2 credentials in order to get a connection. Is this a known issue or should I use the 2.4Ghz to connect to the main router and disable the 5Ghz band entirely?
